Page 28 of 43 FirstFirst ... 18262728293038 ... LastLast
Results 271 to 280 of 424
Thread: Boring Brick
Hybrid View
    16.8v
    Ah, can't help you there, I only have a spare 6S (22.2v) Lipo.
    No problem, thanks anyway
    Harry could you send me a picture of the 18v pack? need to see if it would fit
    So i've put the packs on a discharge/recharge cycle and the one is fine, discharges and charges perfectly, the other pack has been on discharge for about half an hour now and has only had about 200ah taken out, it's not getting hot or anything but i think there's definitely a problem with it.
    Sam what connector are you using on your packs?
  8. #8
    Deans
  9. #9
    Max's Avatar
    Member
    Are you sure you didn't some how plug one of the batteries in the wrong way? Eg. By plugging them into the removable link instead of battery connectors. It seems odd they would give off smoke if nothing has changed. Maybe a short circuit somehow across a dodgy soldering joint to the deans or exposed terminals?
    Are you able to run it on just the one good battery?
  10. #10
    If i was borrowing someone else's battery i'd obviously make sure it was properly held down and protected
