Your price will depend entirely on the materials you use, and the components you select.
£400-£600 would be a reasonable starting budget. For a rambot the cheapest ive seen it done was out of wood with drill motors and so on. That was around £100. Whatever you wan to do with it, it should not go over £1000. Shouldnt even get close to that tbh, but if you have £1000 then that would let you buy spares and make the body out of a cheaper material first to get the shape you want.
But really, the price is entirely up to you, and im sure others could tell you what you can get for about £500 if that was your budget
