Hi,
Trying to drum up some funds for life related stuff. See if I can get a bit for these things![]()
Probably won't be sending stuff out until new year, avoid the worst of the mess of a postal system.
PM offers and questions. No worries. Alu plate the things are sat on is not for sale.
First up, a rather lovely collection of motors. All the 550s are ex 12v drill motors. The 4 aren't identical, but they are 2 pairs, so could work if you were wanting to use all 4 in something. The other two motors are firebolt rc car motors, fast things run off 7.2v or 2s lipo. All could be good for spares or for Beetleweight drives or weapons maybe? As you can see, they have had some use but work okay. 12awg silicone wire on them, if needed I could add some connectors idk.
Here we have a 1-3s Lipo charger, nothing special no balancing, I've got a few leads for it. Good size for Beetleweight batteries I guess. Never used it myself, but it turns on fine etc.
2x 70a 24v relays. Used these powering s900s before. Not the finest controll method, but might be useful for something.
Turnigy battleswitch type thing. RC on/off switch. Used this with the relays before, but could be useful for something.
Misc small motors, could be useful for some ant/beetle bits maybe?
Wiper motor, possible featherweight lifter
T10 timing pulley, 40 tooth I think and its 25mm wide
http://i947.photobucket.com/albums/a...g?t=1387369119
2x 100mm blue wheels with nut insert
2x 75mm wheels, plain
aluminium box
4x red 50a conectors, good for links or just beefy conections
4x grey 50a connectors, one has no contacts or wire, its just the casing.
http://i947.photobucket.com/albums/a...g?t=1387370699
2x 80 tooth sprockets, minimoto I think? takes 6mm chain. Has a 26mm hole in the middle (I've got some 26mm OD 10mm ID bearings if interested)
2x 8 tooth sprockets, 6mm again
A handful of 6mm chain that I'd want to go along with the sprockets.
http://i947.photobucket.com/albums/a...g?t=1387369083
Antweight drum, got M4 bolts in it for teeth. But not many lol.
Misc drill spares, there is defiantly enough for one full gearbox with a spare stage, maybe useful for a custom planetary self righter? 4 carrier plates, 4 ring gears, set of pinions, drive gears, shaft and left hand bolt, and some 3/8 nuts. Want this to go in one hit.
Heatsink/fan that I think came attached to an old sabertooth controller.
http://i947.photobucket.com/albums/a...g?t=1387284882
Possibly for sale, old raptor/feather chassis. Made of 4mm steel, 10mm alu and 5mm alu. I have a 2mm ti wedge for it somewhere I think, and a set of NiCADs but they might be a bit knackered. Drive is 2 drill motors, 9.6v I think and 40mm wide banebots wheels which have great grip.
Offers on everything. Thanks
