Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Antweight help
Hybrid View
    Max's Avatar
    Member
    Hi everyone,
    We are planning on making a couple of antweight robots at school, a lifter and a spinner.
    I'm thinking we can use 2x botbitz 8v 50:1 motors, 2x botbitz 10a escs, one 2s 350mah 20c lipo (http://www.hobbyking.com/mobile/view...=&idparentcat=).
    Then we just need RC gear.
    Does that all sound alright?
    Also what kind of size servo do we need for a decent lifter?
    Cheers
    Sounds good to me, but 10A is rather excessive. In ants you can get away with 3A easy (been running my 4WD one on 3A controllers, never let me down)
    Lifter servos, I would recommend a HS82-MG, metal geared, can take 7.4v and quite quick when needed (check out any video of Stewie to see what a full 90 degree sweep is like).
    One battery ? Or is that a typo ?
    Max's Avatar
    Member
    I was thinking just one battery per robot, is the capacity too small?
    Can the receiver take 7.2v or do I have to wire the lifting servo directly to the battery?
    Sorry Max, I was sleepy when I wrote that . The capacity is fine, in fact for a competition one it's probably overkill. Bulletproof runs one the same size and he takes about an hour and a half of constant use to even slow down.
    As for lipos to receivers, NEVER DO IT! They just can't take it. Take the positive from the servo and wire it in before the speedos. The other 2 can do in the RX. Don't forget to cut 1 wire from the botbitz ESC's because they will have a BEC each, only need 1.
    Max's Avatar
    Member
    Thanks Dave,
    Would this brushless motor be appropriate to run a horizontal bar spinner (directly connected so 1:1 ratio)
    http://www.hobbyking.com/mobile/view...dparentcat=518
    The weapon would be like this one:
    http://www.fightingrobots.co.uk/thre...robotics/page3
    It is 1400Kv and would run on 2s giving about 10,000 rpm which sounds way to fast to me but I'm not sure!
    A little heavy perhaps but perfectly useable. Just be wary of the wires, they look like they sit a bit close to the 'barrel' of the motor.
