The drive issue sounds like a trim issue. It's probably worth your while to check the DIP switches are in the place you want (some of the steering and mixing functions can be messed with).
Red light on the sabretooth can be caused by all sorts: rogue signal, voltage drop (which can also explain the drive randomness), or conflicting BEC's (both the sabretooth and the brushless have one, you need to disable one or the other.
The other option is the battery simply can't hack it, needs a bigger one.
Dr Weston, robot diagnostition at your service.
