Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 122
Thread: pneumatics for featherweight
Hybrid View
    Weight for the setup depends on what type of components you'll use, my current setup weighs 2.5kg, my previous one was weighing more than twice the weight.
    Most components are paintball stuff, and relatively inexpensive. The force this system delivers is about 300kg at 10bar, depending on how you connect your ram should be more than enough to throw 12kg robot in the air. Dont have any experience with linear actuators, but I think they make more of a lifter rather than a flipper.
    Regarding polycarbonate and pneumatics I'm not sure, but I can tell you that recoil might be a problem depending on how you mount the ram. Mine was mounted vertical, on a base of 5mm hdpe. No problems at all, but being vertical, the force was transferred directly to the floor.
    hope this helps a bit...
    Will post the links to the various parts when I find some time. Off hand I dont remember the cost of the whole system, but it should be below £100.
    By the way, 2.5kg is the weight of the pneumatics only! To that you have to add the weight of the robot...
    So here's the list of parts I'm using, changed some of the components of the previous build to improve the efficiency and reduce weight.
    Buffer/Main tank (x2)
    http://www.ebay.co.uk/itm/PaintNoMor...item4ac26a5dfb
    These tanks are fitted with pin-valves, the buffer tank does not require one so I modified the pin valve and used it as an adaptor. Thread on the valve is 1/2"bsp.
    Have a look at the 8th and 9th posts of this thread:
    http://www.fightingrobots.co.uk/thre...lve-help/page3
    The main tank requires an on/off valve to be connected to the pin-valve:
    http://www.ebay.co.uk/itm/New-CO2-AS...item417105e281
    The main tank is connected to the regulator via a braided HP hose. The hose is connected to the on/off valve at one end and at the other end to an adaptor.
    The adaptor is 1/8"npt to 1/2"bsp, and connects to the inlet (female thread) of the regulator.
    The HP hose comes in different lengths, 6",8",10" or 36"
    http://www.ebay.co.uk/itm/New-Paintb...item41715aef1d
    Adaptor regulator to HP hose:
    http://www.ebay.co.uk/itm/New-paintb...item4857c1c42a
    Quick disconnect fittings (to connect HP hose to Regulator adaptor):
    http://www.ebay.co.uk/itm/New-Paintb...item416f505f80
    LP regulator:
    http://www.ebay.co.uk/itm/NEW-PAINTB...item2a1dff3251
    I use a 5/2way valve on my system and the ram is single acting, retract is by bungee. The valve I'm using is very small and rated at 8 bar, but will handle higher pressure. Ports are 1/8"bsp...the smallest possible, but this will not affect flow in any way.
    http://www.ebay.co.uk/itm/DC-12V-2-P...item5aebfa2b74
    Pneumatic fittings I used these, they are rated 15bar.
    http://www.ebay.co.uk/itm/6mm-Push-H...item19d9a4c2cb
    Quick exhaust valve there are two types, one is heavier than the other. This is the difference between the two (9th post)
    http://www.fightingrobots.co.uk/thre...d-diary/page12
    QEV
    http://www.ebay.co.uk/itm/1pcs-QE-04...item51aa096206
    Hope this helps.
    Chris
    Last edited by Liftoff; 26th October 2013 at 14:09. Reason: Copy and paste links...Damn tablet!!
    To fill a paintball bottle you'll need a Co2 fire extinguisher and a fill station similar to this:
    http://www.ebay.co.uk/itm/NEW-Paintb...item41570db720
    Basically you remove the nozzle from the extinguisher and connect the fill station instead. The paintball bottle is connected to the on/off valve on the fill station. One of ball valves on the fill station is a vent valve, the other is the fill valve. To fill close both valves and then open the extinguisher valve. Slowly open the fill valve, the pressure will also open the pin-valve on the paintball bottle. You have to weigh the amount of Co2 you're putting in the bottle ( they are marked 9,12 20oz etc).
    When the weight is right close the fill valve and extinguisher valve, and open the vent valve...then you can disconnect the bottle from the fill station and you'll have a ''full'' bottle.
    Best is you get someone who did this before to show you tho, as if not done right you might hurt yourself...we're talking about 50bar here.
    Alright alright.
    Other than that, can you recommend me linear actuators that i can use on my robot to lift a 15-20kg robot?. i will go with biohazard like 4 bar linkage on my other bot.
    Please link me something from here-
    http://www.aliexpress.com/store/108393
    Basically,
    i am thinking of making something easy and cheap. you tell what is a good idea for a beginner who just did wedges?
    I have tried 4 bar mech already using some kiddo mechanical kit, it ran pretty good.
    15 kg lift over 300mm.
    This will do that.
    Your cylinder is custom I take it and is reset by bungee cord or springs. Do you know of a good double acting system that is this tight?
