Alex....The Slaughterhouse doesn't follow the FRA rules. The rules for the FRA beetles are a different weight class at 1.36 kg.
The Slaughterhouse is an arena run by roboteers for the roboteers. If you want to follow the fra rules then no worries. The champs will be the slaughterhouse champs not the FRA champs.
I believe you are building a beetle weight arena too....will you be using the fra rules at 1.36kg?
