It needs to be clear that the light is on when active. I've seen a few machines use LED strip lights effectively for this. You need to ensure that the LED can be visible from the outside, but this does not mean buried in the bottom of the machine and you can only just see it. You should not have a problem to drill a hole and stick an LED into it to be sure.
