Weld/wire the cells together myself and apply my own heat shrink. No visible markings to indicate what i'm using.
It's starting to look like the majority of the cost is going to be on batteries. Is this the case for most builders?
Whats the cheapest way of getting 36V that will last long enough? I have 4 motors here that each draw 60+ Amps when stalled. They weigh 1.1KG (ish) each so i need to watch my weight because the chassis wont be light either.
