Every single nimh cell is 1.2v nominal, every single nicd cell is 1.2v nominal, every single lithium polymer cell is 3.7v nominal, every single sla cell is 6v nominal. As long as your charger can charge and is set to the cell chemistry you are using it will charge it. You can't get cells that are a different nominal voltage that the standard as far as I am aware.
