Page 15 of 20 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 198
Thread: No Toy Robotics
Hybrid View
    Deal Extreme stuff. It works for a while.
    any body used these npc motors, might make good single stage perm motor replacements little under powered but might just squeeze in
    http://www.robotmarketplace.com/products/NPC-02446.html
    NPC gear is generally good quality, although that motor looks like a generic Chinese design. For less money & weight, you can get the AmpFlow E30-150 Motor, which has more power and better construction. If you can deal with the extra RPM, it beats the NPC motor hands down. If you want more power, the AmpFlow F30-150 Motor still weighs less than the NPC one.
    agreed but it also has treble the price tag out of my league im afraid
    The E150 is $10 cheaper than the NPC motor with more power output and torque. as long as you can fit a bit higher gear reduction, its has to be better. I'm assuming its to drive the axe?
    I have been looking at the e150 would just fit at a push with the extra gear stage. and it is to replace possibly the drive system on my hw ceros as the perms just don't work well and there is so little space to fit anything else.
  8. #8
    generates the same power as bosch 750
  9. #9
    torque is the problem#
    bosch 750 - 11nm
    e30 150 - 5nm
  10. #10
    You have to remember the Ampflow rating is peak power output, a Bosch, is 750 watts continuous, peaking at about 1.2kw.
