Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 71
Thread: "scratching the surface"
Hybrid View
    Max's Avatar
    Member
    That style of robot has been built before but needs complicated electronics to make it translate whilst spinning or else no robot will bother driving into you whilst you are spinning.
    A little bigger for extra hardware and weight and clearance for internal mounting for motors. Also smaller wedges so that I don't loose power because of overlap in the middle.
    sounds very interesting. You will need more speed though but I like where this is going.
    This looks good! Need to remove some of the 90 degree corners on the back edge (True spinners will be spinning faster than you are!) Melty Mind Drive as its called is difficult but it might be possible with an arduino. You need an accelerometer and a gyro in their to work out your spin speed and the forces so you can subtract them from the movement you want, thus keeping the spin but giving you translation.
