Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Using 12v led strips on 24v
Hybrid View
    Voltage regulator
    Its easy, take your 12v strip and cut it in 2 bits both same lenth, then wire both together in series. Worked for me in toxic for a few years. My 2 x 12v strips run on 30v quite happily.
    Max's Avatar
    Member
    Quote Originally Posted by terry View Post
    That's a brilliant idea! I've already got it in 2 strips in parallel so dead easy to change it to series. I also think I've solved my shorting problem so may have time for a test run tomorrow, it should be much faster now with 24v, 150mm wheels as ive fixed the half throws from the mixing.
