So, I'm posting this up early to give people a bit of a headstart to get designing. As the name suggests, this one is all about vapourbots on a slightly different arena to usual.
The Ice Arena is essentially what it says on the tin, unfortunatly I can't find the information for the exact thickness of it, but it's basically as follows (if someone has any specific data that would be welcome):
A 10m deep tank of water, on the top of which is a crust of ice thick enough to support a vapourbot with a sensiblely large contact to spread it's weight, but not enough to support something with fairly limited contact.. For instance, tornado or storm 2 would be able to move around, stinger on the other hand might have more problems.
Considerations:
- Traction will be way less than usual
- Most attacks, even ramming will run the risk of breaking and sending their foe to a watery grave.
- You are completely allowed to have a submersibal robot if you wish - falling in the water isn't an automatic knockout unless it kills your robot.
- Do you want to stay on the ice or break it? The ability to go underwater is undoubtedly valuable, but most attacks will be more effective on a solid surface.
Same rules as before, only entries are one which get in on time, this time the closing date is Midnight GMT on the 3rd of August.
EDIT: Due to Martijn asking, the clusterbot rule here is no clusterbots. They take a bit away from the challenge in this particular round.
