I'm very sorry about posting all these help threads, I'm almost there now with my design so there shouldn't be any more after this!
Basically, I'm building a horizontal bar spinner, much like how NST's and Last Rites' are - I've never built a spinner before, so I wondered if anyone has any advice or knowledge from past experience for what sort of materials would be best to hold the thing together?
The plan I had was to use a 4kg (ish) mild steel bar (not entirely sure of the size yet, but it'll be quite large I think, hopefully interchangeable so I can go for thicker teeth to tear panels off, or thinner blades for more localised damage) on a bike axle so that I can get the bearings/ratchet system and the gears on it all in one go and it's cheap which is good because I've practically maxed out my budget... Not sure what RPM it'll be going either, I think I've figured it out to be going about 6000 RPM with the gearing and motors I'll be using. Hopefully anyway, my calculations are always wrong...
For the bulkheads, I was thinking 3mm Box section as a frame, or something along those lines but I'm not entirely sure how that'll hold up when the bar hits something to be honest. I'm using this motor as well, on 6s if that helps! http://www.hobbyking.com/hobbyking/s...0KV_2665W.html
Thanks in advance for any help, hopefully I'll be better at all this once I've been in a few fights!
