Results 1 to 9 of 9
Thread: Motor & sprocket Help please
Hybrid View
    I'm inclined to say go for the 18v drill setup, purely to be different. Though many (ourselves included) start out with four drills overvolted. Done right it makes for a nice powerful machine, but no matter what you do, it will be dogged by reliability problems. Reliability will be greatly improved without overvolting.
    Can you get a picture/any manufacturing numbers from the motors? Chaindrive is perfectly possible, but if the motors are fast-running (quite likely unless they're really quite big), you get into needing two or more stage reductions for it to have the power to drive the machine, and that gets pretty complicated (and heavy). Single stage means, yes, from the motor directly to wheel.
    In short, if you can, pictures please!
    Hi ELLIS,
    i Will try get some photos taken over the weekend as currently all my gear is neatly (cough..cough) packed away due to moving house in a few weeks time, i wanted it to be slightly different like you said, as i have a set of four 12v motors with gear boxes and luckily enough in a few more weeks time i will be getting 2 more 18v ryobi drill motors this time with Gear boxes.So not sure whether to hold out until i pick them up and run them with gear boxes on and run a chain straight to back to a set of wheels as wouldnt need to worry to much or gearing them.
    Whats your thoughts
