If they don't have gearboxes you'll struggle to get enough gear reduction using chain and sprocket. You will probably need about a 24-1 reduction so even if you used gears and managed to fit a 10mm diameter gear on the shaft then you could only get a 10-1 ratio with 100mm wheels and a single stage reduction. I'd suggest getting some drill or Gimson gearboxes or banebots (I don't think these are available individually) to do the reduction then use a straight 1-1 ratio on the chain to run to each wheel.
Hope that's helpful
