Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Metal thicknesses and recommendations for spinner proofing
Hybrid View
    with that design you could do 20-30mm hdpe sides cut to shape and bolt metal plate to the hdpe at the 3 angles you wanted then if 1 gets damage you could just replace the the 1 section
    Useless, the lot of you. None of you came out with it.
    Any thickness of material will come off if not secured together securely.
    either should work but i f i were using 20mm + then i would use something like these screwed into the hdpe
    http://www.ebay.co.uk/itm/Pack-of-4-...item25738175ae
    and then bolt through the base plate, lid etc
    you might be able to get versions with a larger external thread
    There OK, but to me, they look very liable to strip the HDPE. I would probably just go for self tappers, they have worked well for use so far.
    But the again, I have no experience with them so what do I know !
