Results 1 to 10 of 10
Thread: Electricals/ drive system help (sorry!)
Threaded View
    So sorry for once again asking for help, but I really can't get my head around all this electrical business, and whether my current setup's going to work...
    I'm attempting to use a brushless motor setup, with the following:
    Motor (2X) http://www.hobbyking.com/hobbyking/s...0KV_2665W.html
    ESC (2X) http://www.hobbyking.com/hobbyking/s...arehouse_.html
    Battery: http://hobbyking.com/hobbyking/store..._6S1P_25C.html
    Would this work? I may also have a third motor/ESC pairing on there too, but could do that on a separate battery...
    The main thing is that the motors, under the testing data pull 82A, with the ESCs being up to 85A but the maximum amps for the motor are 90A (it says I think) and then there's the whole thing about the power usage too, whether it'd work for a prolonged period of time...
    I still need to learn about all this, I think... Brushless and LiPos seem a lot more complicated than my old drill motor setup!
    Thanks in advance, it's really appreciated!
    Last edited by Flag Captured; 12th June 2013 at 22:49. Reason: accidentally the numbers wrong :(
