Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 3 x 24v nicad packs
  1. #11
  2. #12
    Just make sure you have a method of safely discharging them. I don't think there is any mention in the rules about capacitors but the size you would need would substantial and could give a severe shock either to you or to the arena marshalls (might want to check with event organisers that they would be happy with capacitors)
  3. #13
    If you have a 72V motor and can demonstrate the battery pack is compatible to the motor spec,
    All associated wiring has capacity to spare and you have complied with all the safety rules, Locking bar, link etc.
    I don’t think the EO would have as much a problem with this. As a bank of capacitors ready to,
    “Cry havoc and let slip the dogs of war."
  4. #14
    But you aren't allowed a 72v battery pack in the rules and he has already stated that the motor would be over volted so it wouldn't be within specification.
  5. #15
  6. #16
    Only 30 cells in series. You can parallel them up no bother to increase capacity
  7. #17
    kane's Avatar
    Roboteer
    6.6 Voltages
    Voltage must not exceed 75V for direct current or 50V for alternating current except where prior approval from the event organisers has been confirmed. Note that batteries may have a higher voltage during charging and care must be taken not to exceed these limits.
    7.5 Maximum Cell Count (series) and voltage
    7.6 Parallel CellsBatteries cells may be connected in parallel to increase capacity and discharge current. Caution must be taken with NiCd and NiMH as these cells may only be connected in parallel during discharge.
    This indeed means that you could use 2 packs of 30 cell NiCds in parallel (total 60 cells). But you could not connect in series.
    Kane Aston
    http://www.makerobotics.com
  8. #18
