Results 1 to 3 of 3
Thread: Drive Motors
    I'd go for the Gimsons GR02, they'll be much nicer than the cannibalized drill offerings, and quality wise wipe the floor with argos drills haha
    Pros:
    All metal gear box
    Metal geabox casing
    Accurate intergrated aluminium mounts
    Motor better quality than super cheap drills
    Motor guarenteed to not be directionally biased in speed/torq
    Shaft has a better bearing
    Semi Cons:
    Shaft is a little long for my design, but it's not an issue if you have room for it
    Max's Avatar
    Member
    But if this is for your melty brain robot then gimsons won't be powerful enough. If it is for a basic featherweight wedge or one with another weapon then they are great.
