I need 2 strong and reliable drive motors for my featherweight, and i am stuck between wether i should go for Robochallenge drill motors or Gimsons GR02's. Any replies welcome.
I'd go for the Gimsons GR02, they'll be much nicer than the cannibalized drill offerings, and quality wise wipe the floor with argos drills haha
Pros:
All metal gear box
Metal geabox casing
Accurate intergrated aluminium mounts
Motor better quality than super cheap drills
Motor guarenteed to not be directionally biased in speed/torq
Shaft has a better bearing
Semi Cons:
Shaft is a little long for my design, but it's not an issue if you have room for it![]()
But if this is for your melty brain robot then gimsons won't be powerful enough. If it is for a basic featherweight wedge or one with another weapon then they are great.
