Results 1 to 7 of 7
Thread: FW basic setup
    Wow. The 4WD Scot bot looks uncannily like the Kaizer I bought off Jamie.
    Probably quite similar, but then most 4WD ram bots probably are. It's a bit bigger than Kaizer, using 124mm wheels and bigger batteries and no lifter so quite different inside.
    Tony, just Taller & without the front wedge as far as I can see it. The batteries are about the same volume due to them being 2*6V SLAs, the electronizes were laid out like that too for the 2010 champs.
    More importantly,it's the front panel that reminds me. The underlap behind the front panel. I pulled that forward in the currentdesign to support the front wedge.
    I must have a go at a 4WD one day.
    Ahh I see, didn't know it ran SLAs.
    Hopefully the 4WD versions run just as well as the 2WD ones but with a bit more power behind them
