Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: motors/wheels
Hybrid View
    ok ive got a couple of the 24v reliance motors, which i got from Roger Plant a while back
    i was thinking of using them to run a 4wd system using 8 wheels in pairs (maybe 12 in sets of 3) with a 3-1 , 4 -1 or 5-1 reduction
    3-1 should give 14mph ish
    4-1 11mph ish
    5-1 9mph ish
    does anyone think it will be a powerful enough drive for a heavy weight
    hopfully if its ok then i should be able to make the robot quite small and compact which means i can put the weight in to the armour and weapons might go for weapons pods and make a few
    starter motors draw too much current to be of any use
    and starter motors aren't designed to go in reverse. Only one I know of that run starter motors was Sumpthing that had 2 per side, one for each direction if I remember correctly.
    Theres no point in going 6-8 wheel drive unless your running LEMs or Eteks. Having that many wheels will be very inefficient and I don't see what your going to gain.
    dreadnought and a few other early robots used starter motors
    and i was only thinking of using 8 wheels in a 4wd config 2 stuck together as their thin
    Project One used a Ford Fiesta starter motor @24V, completely rebuild for reverse -done with an Albricht SW88 24V B and a Sevcon SL1 speedo. That motor went into Scarab as pump motor.
    Team RCC with Blackdevil Warzone had a machine with 3 startermotors in it. 2 for drive, 1 for the weapon, and those 3 together drained a 12V 45 Ah SLA completely in a fight.
    The main problem with series wound motors is that they are very inefficient especialy compared to the modern PMDC motors.
    If you're very lucky, you have an efficiency of 60%, when a Bosch 750 does 75% easely.
    might think about selling them since you cant get spares anymore, im guessing roger plant doesn't sell them anymore
