Page 12 of 12 FirstFirst ... 2101112
Results 111 to 113 of 113
Thread: Corvis (temp bot name) rough ideas.
  1. #111
  2. #112
    DC-DC inductor boosting is fine just needs some careful thought. The tricky part is getting the circuit to handle the current needed. You can't get around the basic physics that a weapon using x amps at y voltage is after the inductor is going to demand 1/3Y and 3X before it. Also DC-DC boosting is prone to failing or overheating in high power setups. Just suggesting that you make sure that this setup will definitely be able to provide the power needed.
    Sources: DC boosting is very common in coilgun making, spent my last few weeks researching it.
    EDIT: The voltage limits are to do with regulations concerning what is low/high power equipment. I believe the 72V is the threshold. If there were robots using over 72V it would affect the event insurance or precautions needed to be taken I presume.
    You can pretty much boost up to a few kV still with minimal fire risk.
  3. #113
