i think this is a common problem but i am wondering if people can help me with it. Im using a DX6i with the ELEVON option selected. To counteract the 50% throws and get full speed/ power, ive used the following youtube tutorial:
The bot, which uses two self-hacked 85a ESC, works perfectly fine until for example you push the stick above 75% forward and 75% left, expecting the bot to start turning as the left side of the drive slows down and letting the right side bring the bot around to the left. At the moment, its doing the opposite in this situation and bringing the bot around to the right. it works as intended at lower speeds and when using the ELEVON option on its own without the messing with the 50% throws.
Cheers
Dan
