My welding helmet has started playing up recently. Either it won't auto-darken when the arc strikes up or it will un-darken halfway through a weld. I've tried adjusting every variable setting on the mask with no discernible difference. I don't really fancy arc-eye so I'm on the lookout for a replacement lens/filter section. The closest I've found to the one in mine is this:
http://www.ebay.co.uk/itm/Solar-Power-A ... 460d9514ab
However it's from Hong Kong and I'd prefer not to order from there if I can avoid it. Does anyone know any good UK sources of these bits? I've had a quick Google search but most don't seem to have the dial attached like the above eBay one.
Alternative is that I buy a new mask (not a major problem as they're pretty cheap) but a lens/filter replacement would be easier.
Thanks
