hi all
looking at shedding weight from my hw, flipper pin is 30mm solid steel bar running full lenght of robot chasis and weights nearly 4kg, there are also 3 short bras in the flipper arm, total weight of over 7kg. need more weight for armour. looking at replacing the main pivot arm and one flipper bar, here are some suggestions i have been thinking on all should work due to there material properties just wondered if anyone had any dealings with them.
1, use seamless mild steel steam pipe 3-4mm wall - very strong but expensive
2, t6 ali solid bar 30mm - light but might bend and wear quick
3, t6 ali tube 5mm wall thickness - might fatigue very quick
2, nylon rod 30mm - should just deflect slightly in use self lubing
thanks all
