Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 158
Thread: Pulverizer Build Diary
Hybrid View
    The featherweight design looks pretty cool, and quite unique too which is always nice, good luck building it
    Several remarks.
    1) No wall thickness mentioned
    2) 2m long ain't industrial standard, it's retail standard
    3) Varnished, again retail standard.
    This means it's probably a soft mild steel, thin walled (1 maybe 2mm thick if you're lucky, with anything in between).
    It will do the job, but any decent spinner will chew it up as if it's candy.
    Also, for 2 meter bought at a retailer, I can buy 6 or even 12m unvarnished normal mild steel at a steel-depot.
    I would pay head to marios advice. Look in the yellow pages or online for a metal stockist nearby and phone them up direct. When I ordered up some mild steel tubing even though the delivery price was the same as the material cost I ended up with a good 18m of tube for far less than a commercial entity would charge (they came in 6m lengths)
    Quote Originally Posted by Mega Masher View Post
    Just saying, i will only need around 2 metres of tubing for this build.
    And? 2 meters of box section for £20, or 6m of the same dimensioned box section for £20.
    Worst case scenario you'll sell the surplus for £5, and put £5 in your pocket.
    But me, I prefer to have a surplus in my basement/workshop/gardenstoragebox.
    Max's Avatar
    Member
    Just a couple of questions, How do you plan on bending it into a perfect circle? Are you planning to weld the box section together? How are you going to mount these rings onto bearings so it can spin? And finally how do you plan on getting drive to the rings so they spin?
    For box section I would find your local metal workers and pop them a visit explain what you are doing and try to buy the steel from them, they could probably cut you off a 2m length.
    To be honest, i have no idea
    I wouldn't attempt to bend it myself without the correct bender for square tubing, most probably it'll collapse, more so if its a thin walled section. But you could find a pipe bending shop in your area and they'll do the job for you, probably you won't even need to buy the material as they will have themselves.
    It will be neater than if you try to cut/weld it to shape and saves you a lot of sweat!
    ps. I dont know the local costs involved tho!
