Page 45 of 47 FirstFirst ... 354344454647 LastLast
Results 441 to 450 of 478
Thread: Skipdiving Robotics
Hybrid View
    Looks like it will be very tough and sturdy - what width and thickness is the box section being used in the photos?
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
    Awesome!
    TBH, Short of welding the panels to the box frame, I would think some quite meaty bolts, nuts and washers (M8/M10 type stuff) would be plenty to keep the panels to the frame. Makes it look quite industrial as well. As for the frame itself, 4x (or 8x) L shaped brackets on the interior so the panels sit flush on the box section (again, held in with nuts/bolts/washers)?
    Did you decide on a weapon at all?
    FW: Azriel
    MW: Jibril, Kaizen
    Btw to embed images from imgur just use the add image button in the editor and use the From URL tab. You need the link from imgur with the image name though like this: http://i.imgur.com/Ik9NXoG.jpg so I you can just slap .jpg on the end of the link and it should work.
    E.g.
    Looks neater than mine at the moment!
    FW: Azriel
    MW: Jibril, Kaizen
  8. #8
    yessss! #1fan is stoked for the return of this thread! looks plenty robust, what are you thinking about putting in there to shift all that metal? if you need a name i want to put forward "Aluminion" lol
  9. #9
  10. #10
    Looking good! Following on from Alex's suggestion, I'd like to suggest the name 'Silver Bullet'.
