Page 30 of 55 FirstFirst ... 20282930313240 ... LastLast
Results 291 to 300 of 544
Thread: Robo Challenge - 2013 FRA UK Featherweight Championships!
  1. #291
    cliveb's Avatar
    Roboteer
    Quote Originally Posted by Mouldy
    Quote Originally Posted by john
    Too easy for Beauty 2!
    ...360's working...
    good :wink:
    Team Toon:
    Heavyweight UK Champion 2015
    Robot Wars World Annihilator Champion 2015
    Heavyweight Tag Team Champion 2012
    Featherweight UK Champion 2010
    Featherweight Annihilator Champion 2009,2011 & 2014
    Rebel Robots Champion 2009
    Pika Annihilator Champion (Belgium) 2012
    Tanja Trophy Winner 2010
    Team Champions ( Team Barbie) 2011
  2. #292
    The last time those two fought didn't Beauty end up with no wheels and no gas bottle?
  3. #293
    I've only had time to have a quick look at the draws but I think LS4 could be in with a chance. It's draws could be very much to it's advantage, it did very well a couple of years back.
    Only problem is the fight with BitzaWood, which BitzaWood will have to win, but almost could have been perfect.....
    As for my draw, 2 rambots, 2 axes and 2 horizontal spinners. Horizontals will be an issue with my vertical weapon, do I take it off?
  4. #294
    Your disc itself will be fine but I can see the supports possibly going. As a comparison, Will took off his 12mm thick disc against NST as he was afraid it would get bent. I left my 10mm disc on against NST and it mostly survived; it had a big nick out of it but that was all. Up to you really, you know your machine better than anyone else.
  5. #295
    For those fighting Binky...
  6. #296
    How do the teeth look after those collisions?
  7. #297
    They took on about a 2mm radius against the bar in the first test. Nothing changed when we attached the Belling. We could sharpen them again but I think we will leave them like that as they are not compressing any further so should be fine in combat.
  8. #298
    Looks a dangerous machine!
  9. #299
    I've just realised that all 3 of Team Toon's entries are seeded!?
  10. #300
    cliveb's Avatar
    Roboteer
    Team Toon:
