Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Arduino
    Max's Avatar
    Member
    Hi,
    Has anyone had any expiriance using Arduino? Can anyone recomend a good starter kit for a complete beginner?
    Thanks
    I've had a play. Couldn't tell you what parts I was playing with as they are back at my parents place but they have many potential uses.
    What exactly are you wanting to do with it? There are several different starter kits but they all vary slightly. If you want to do motor then I can pretty much guarantee you will need to get some extra transistors or whole ESC's.
    Arduino is like the go-to prototyping tool for basic electronic systems for a huge range of applications. Providing you only need one thread or instructions, where everything follows on sequentially, you can probably do it with an Arduino. Quote from my tutor when starting our project.
    When I started I found that it has been used my so many people and because its all open source that you can find the code for 90% of what you want to do online.
    I did Ardino in my second year and after 20 minutes had found the code to do my entire project. I modified it a bit to fit with the LEDs I was using but all I had to do really was set up all the in's and out's
    Max's Avatar
    Member
    I don't have anything in particular I want to do- I just want to learn/have a go at this kind of thing. Ive found the arduino starter kit on RS components and that looks fairly good as it covers wide range of basic projects.
    Well I have heard this might be the answer (or at least partial-answer) to us wanting Tormenta 2's weapon to be controlled like a servo, in that it defaults to ground-scraping as the joystick is sprung back to centre.
    If anyone can help us achieve this, it'll be greatly appreciated. I admit I haven't looked into it yet, though. I'll try and catch you on FB sometime, Alex.
  8. #8
    I've had great fun with my Arduino, but mostly making musical interfaces.
    @Ellis using an Arduino to control your lifter should be pretty straight forward. Just effectively remake a servo, only with your motor and ESC and an external VR.
  9. #9
    if your just looking to make it like a servo might I suggest you try this
    http://www.lynxmotion.com/images/html/ht01.htm we did something like this for the Scorpion
  10. #10
    Quote Originally Posted by shakesc
    I believe Maddox has used them
    Me, electronics??? Woha.
    Unfortunatly, I have troubles connecting 2 wires...
