been looking at the idea of a lip pack and this seems the best amount of amps for a good price but im not sure whether its the amps or the c rating that your looking for to run a robot
http://www.ebay.co.uk/itm/320982959747? ... 293wt_1151
Nicd, nimh, and Lipo are fine to supply current req in fw , and hw if in parallel the most benefit of Lipo is the weight saving, and also they do kick out the amps![]()
well at the mo im using 2x 7.2v 3000mah battery in series to make 14.4v and its running 4 motors in 1 bot i think more power is required as the nimh pack can only do 30a peak probably and each motor probably uses about that when pushing something
14.4V then. That's a 4S pack, in Lipo it gives 14.8V nominal.
Even a cheap Zippy or Turnegy pack does 30C, and that means on 3000mah, it's 90A rated.
If you don't need the really high end packs, I can advice hobbyking.
Use Hobbyking for my stuff
Did manage to destroy one pack but that was my fault with a deep discharge due to sticking motors, thats roboting
i have found a 4s 2200 mah nano tech that says it can do 25c continous and 50c burst, dunno if that would do i assume the higher the c rating the mor amps it can draw in 1 burst
The C value is exactly what you write Plargen.
The times the rated amp value can be drawn from the pack . First -lower- value means you can draw that untill the low voltage limit is reached. The higher value is the amount of amps that will damage the pack if drawn longer than an instant.
so at 2200mah 25c continuous would be 55a and the 50c burst at 2200mah would put out 110a
That is correct as far as I understand the situation.
http://www.ebay.co.uk/itm/Turnigy-nano- ... 1670wt_919
this is the lipo i have been looking at
