Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 104
Thread: Brutus 2012
  1. #11
    SO.MANY.LEMS!
    Looking very good though, this will be great to fight once its done
  2. #12
    Should have gone with some screwdriver motors, you'd get way better results.
    (this is mad/brilliant!)
  3. #13
    We´ll try to get Brutus ready for Portsmouth ... it will be without a weapon and not it´s final dsign ... first we need about half a year learning to drive Brutus and make it reliable ... in the mean time we´re designing the weapon powered by a permmotor ( a weapon like sewersnake or something in that order) ...
  4. #14
    Utterly pointless putting 4 lems on the drive with only 4 wheels. You will never get the power into the ground. Even with tracks you would struggle not to spin them. Seems little point in wasting the money and weight putting 4 lems in when two would more than suffice.
    Nice machining but if the base idea is flawed then there is little point in spending the time on it.
  5. #15
    pointless to give an answer but you will see why ... overpowering something got no use use ... why built a fullbodyspinner when it is easily to flip ... why built a supertornado when it´s only a pushbox ... that´s where the creativity of each roboteer is ...
  6. #16
    Still none the wiser to the thinking behind the machine. I'm not looking to be confrontational, just trying to understand the logic behind building a machine that is obviously so overpowered that it will struggle to use the power it has available.
  7. #17
  8. #18
    The thinking has to be just to smash and slam and bludgon the opponents into submission, but I agree with Gary; I can't see you ever getting all the power down even with four full width go-kart tyres. 2 would be more than enough to hit things so hard it could be sent out the arena!
  9. #19
  10. #20
    Why buy a Bugatti Veyronwith a 1000Hp+, if a 29Hp 2CV will do the task too?
