Hey everyone, I've been reading around on the forums and now I believe I've got the majority of parts decided on. If you could just quickly have a look over before I confirm the ordering of everything.
So its just a simple wedge robot, which will most likely involve a lifting arm using a car jack, or an actuator. 2WD using Gimson motors (the 14.4v version) to power it. The wheels are 78mm from the Gimson site although I may also get the blue robochallenge wheels (100mm) too.
In terms of batteries I was looking at hooking up two 9.6v NiMH packs in series most probably 3.7Ah, 4.3Ah or 4.6Ah (advice please).
I've got a spare 16.8v drill around which I may be using on the car jack. I've already got the transmitter and receiver. Entire armour and chassis will be HDPE, most likely 10mm-12mm.
The main thing I'm unsure about is speed controllers. I've seen many recommendations around the forums such as electronize and botbitz. I myself was looking at the Sabertooth 2x25 (or the 2x12 is it doesn't need to handle so much current).
Thanks in advance for any help! Dan : )
Also, this bot is most likely not going to be competing or anything, its just something I've always wanted to make (since robot wars is awesome!). Perhaps I'd make and compete with a second FW![]()
