Page 5 of 19 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 190
Thread: Team Bitza
  1. #41
  2. #42
    Quote Originally Posted by PJ-27
    I need to regulate the 24v in Bitza down to 12 for some cooling fans what's the best way to do this?
    Putting 2 the same fans in series is the most easy way to do it.
  3. #43
    As mario say's either 2 fans in series, or just put a resistor on. Those Jaycar SSR's are the cheapest I ever found - although fragile they don't seem alot different to the £80 ones we got from RS years back.
  4. #44
    Good find Chris!
    That's a good point Mario but I've really only a need for one fan, worth bearing in mind though.
  5. #45
    How big a fan do you need? I have a brand new 24v fan for my victors which I don't need (seem to run fine without them) if you'd prefer to run it off battery voltage.
  6. #46
    Good find Chris!
    If you have the weight left, a second fan probably is cheaper than any solution involving step-down.
    But, what are the stats of the fan? Size, powerconsumption and such
  7. #47
    Currently plan on using a PC fan, which is perhaps a bit too big (let alone 2). Their use it cooling ESCs so your Victor ones could be perfect!
  8. #48
  9. #49
    I'll try and get the dimensions for the fan tomorrow and you can see if it will fit.
  10. #50
    Cheers Dave!
    That's true Ben, but for £1.50 it would be cheaper to buy one. Maybe if I wanted a project!
