I'll be putting up quite a lot of things for sale over the next couple of weeks. Some parts which were used for Tiberius or similar projects and some random engineering things I've aquired over the years for robot projects and never used.
First up....
- A 40MHz 3 channel Transmitter and Reciever boxed. Used this for the early Tiberius on Robotwars. Quite old tech now, but all tested and works fine, so a good cheap starter set for an ant weight or RC car. (not sure which other weight catagories allow 40mhz these days?!) £10
- An NCC-70-24, An old 4QD single direction speed controller. Can just about power a bosch 750. I used it to run a bosch on an electric go-cart I built when I was a kid. £15
- Dual Channel interface board from 4QD, got a couple of these, one still in original bubble wrap. Probably no-one who uses these anymore but thought i'd post anyway. £4 each
- FS1 failsafes, 2 off useful with 40mhz equipment, £4 each
- Power supply 15v 25Amp, I've got two of these and they are very useful. Only bought the second for quick bulk charging of Tiberius (one power supply on each A123 battery pack). As new so looking for £65
- An old Lead acid battery charger (Yuasha not hawker voltage) Can do 2, 6 or 12 volt batteries, or be used for car batteries. Slow 0.5amp delivery current. £4
- Couple of drill batteries and chargers from 12v drills which I bought for the first NST drives. Hardly used the batteries so they are pretty new. Not great power to weight but could be useful for testing £ free to the first person who wants them going to Robo-challenge award ceremony.
- Norgren pneumatic regulator, no idea what this is worth... £5
- A wiper motor, took the photo of these before testing them and found that one runs fine, the other draws more current than at no load so is faulty and will be scrapped. the good one.. £ again free for collection at RC AC.
