Ok been contemplating this one for a while and I think I€™ll sell it. This is the vertical disc assembly that Kenny manufactured a number of years back (CNC) and I bought off him with the intention of finishing it off. I doubt I€™m going to get around to finishing it so want to sell it on in the hopes that someone will be able to do something with it. I am however NOT selling the disc with the assembly. The disc I will use at some point when I get around to having a permanent workshop.
What would be included,
-2 mirrored 40mm wide aluminium (can€™t remember the grade but it was a high one) vertical disc supports with bearings and mounting space sized up for a scorpion 4025 brushless motor
-Central shaft (20mm at bearings) with an integral pulley blank (would require further machining)
-A second pulley blank that is bored to slide over the shaft
The distance between the two pulleys in the centre is around the 12mm mark
This would make a fantastic start to a vertical spinner. Sadly one which I don€™t have time to finish. PM me with sensible offers.
