PJ you can have the speedos
you will make better use of them than i will
Cheers!
how about these http://technobots.net/
you haven't given a link to any specific product just the technobots page
hmm its the 1.5mod.holostraform gears
mmmm plastic gears, that's a good idea.
thought you were following the advice given and doing something simple?
axe bot first
then my 6wd rs775-18 robot
are the names merciless peril or paranoid taken?
ok i will take those names
how about technobots mod 1.5 17mm gears
they will be fine for my.superpower robot?
also can i make motors draw a lower average current.with good cooling?
thanks
enough stupid questions
can i use solenoids to control an.axe and is that my best way to do it
axe relays would be pretty pointless
A soleno¯d is a coil that moves a center part.
The biggest coils suitable for featherweights can move at best a pound, if the time is short and the coil overvolted to the melting point.
In other words, a soleno¯d is handy to control things that can do bigger jobs.
A Relais is in most cases a soleno¯d that closes or opens a switch.
