another picture
another picture
You put the grubscrews where the metal balls used to be after you tip them out. Ellis' video shows you where they go
ok thanks Max.
use atleast 2 grub screws per motor (use the correct size) but do not tighten otherwise you will completly lock the gearbox and start to bend and warp the plastic gearboxes
does anyone have a link to the screws because i couldn't find anything in Wickes
i think however im not 100% sure because its a while since i did this myself you will need m5 gurb screws wait before ordering until someone else confirms
http://www.ebay.co.uk/itm/M2-M2-5-M3-M4 ... 2a176165ce
the m5 x 8 (8 is the length in mm) will work fine
Got mine on Ebay, although I pretty much rounded off everyone.
We got 2 packs of 10 from Ebay, 5mm long m5. They're too short, really. Get 8mm long for safety, they should come just flush if you tighten down.
Also, they're likely to be a 2.5mm size allen key, make sure you have one.![]()
I know its a little of topic, but can someone post a link to the speed 900 replicas
Thanks![]()
i can't find them so i thaight they sold out
