Page 19 of 27 FirstFirst ... 91718192021 ... LastLast
Results 181 to 190 of 261
Thread: Graupner motors
  1. #181
    Max's Avatar
    Member
    What did I say?
  2. #182
    Quote Originally Posted by Max
    I would just go with drill motors for your first fw. The gearing will be expensive and the gearbox has to made with a lot of precision. I think a drill motor is equivalent to a speed 500 motor so in theory 4 drill motors are more powerful than 2 speed 900s. I think the botbitz controllers would be fine on 1 speed 900 but possibly not 2 speed 600s
    you are referring to the size of the motor not the power.
    overvolted with supergrippy wheels.
    4-6 b&q drills
    sounds good enough.
    it was a long time ago you posted that Max btw
  3. #183
    It's quite ridiculous how you're playing top trumps with power figures, stop pretending you've come up with a great new idea that's never been done before (usually for good reason) and build something!
  4. #184
    I've got till October to build something.
    will do something in 3 ish weeks
  5. #185
    Quote Originally Posted by archie2000
    4-6 b&q drills
    sounds good enough.
    Again, the notion here is that drills are underwhelming, or that they won't be good enough. Which isn't true. They are certainly good enough.
    Here's a battle Tormenta had with Tiny Toon (which I believe runs Gold motors?) at the champs:
    We were beaten because Toon had a lower front, and because we were against one of the best drivers in the game. :P
    But as you can see, it's just as impressive visually as the very powerful setup in Tiny Toon. Once or twice we got a push in and we didn't struggle at all. Not a great example because we were being bashed about constantly but that's just 4 12 quid drills there, mate.
    These battles are less good because we had dreadful batteries that seriously held back the machine. With the right batteries (what we had for the champs) it was a beast. Even so, it's still pretty good:
    ... el&list=UL
  6. #186
    If you don't believe that a drill has a decent motor/gearbox combo then take a standard 2 by 4. Take a 4 inch screw and try screwing it into the wood by hand. Feel how bloody difficult it is to do it. Take a fully charged cordless drill (bearing in mind the standard batteries are crap) and do the same thing. See how easily it goes in. Point made.
  7. #187
    point taken.
    by b&q drills i mean 12v cordless not hammer drills.
    can i over volt drills yo more than 18v with heatsink?
    4 drills on 18/18+ volts with 6wd system will be good right?
    what speed controllers shall i use and reuse in my robot.
    I'm thinking sabretooth 60a ish kind of amps?
    or a botbits
  8. #188
    You can overvolt 12v motors to 18v, there are a few roboteers that do that (Such as Ellis, which he has said in previous posts.). You shouldn't need a heatsink for that purpose. Motors can run at 50% more that their rated voltage (12v + 6v = 18v)
    As for a speed controller, If cost matters (which I am sure it does), then I would buy some botbitz 25A controllers, same rating as the Scorpion XXL, but 2 of them I think is still cheaper than buying the 1 Scorpion unit from the states (they are single channel controllers like your Banebots).
    If you plan to run 4 motors, I'd get the ESCheap85 ones, rated for 85A, and my victors are rated for 60 and they'll take my Speed 900's all day . I would have bought them had I known about them 2 years ago :P
  9. #189
    shame. i wouldn't had bought the bane bots if i knew about the German speed controllers.
    will i need more than 85amp?
    I'm thinking of either dewalt hammer drills (which i found out that the motors of the b&q 14.4v one would be fine and i.would just need a new gearbox)
    http://mobile.robotmarketplace.com/BP389010-00.html
    rs775s (yay)
    maybe graupner motors.
    doubt they will pull over 85amp but i could always get a 190-200amp hobbyking http://www.hobbyking.com/hobbyking/stor ... 5FESC.html
    i would need 4 i think
    and i would have to hack them brushed to brushless
    thanks dave again
  10. #190
