It's usually a case of either/or.Originally Posted by harry hills
You want to play robots? Then write off your chances of getting a woman.
You want a woman? Then write off your chances of playing robots.
Unless you find a woman that's tolerant of robots, in which case kudos :P
Archie, another possible problem with hammer drills that I found when messing about with some, is that the shaft is free to come out of the gearbox. With standard cordless drills, the shaft is fixed in place and only protrudes about 25mm-30mm out the end of the gearbox. With cordless hammer drills, the shaft can be around 50mm-60mm long. This means that if you use, say, Robo Challenge wheels with nut inserts, your wheels will stick very far out and the shaft could be more prone to bending from impacts when your robot is thrown around and lands on its wheels.
And because the shaft is usually free to come out of the gearbox, you'd have to come up with some sort of restraint to basically stop your wheels from falling off.
By all means feel free to experiment with hammer drills at some stage, but if you're wanting to keep some money aside for your next, more powerful robot, it's best not to spend money on hammer drills then have to spend more money on normal cordless drills when you realise that it's too much hassle to make the hammer drills work properly as drive motors.
