OK so you have a 1000A lipo and a 300A fuse, all seems very good with a more than adequate safety ratio.Originally Posted by graeme
I had a look up to see if I could get some reasonable time/current characteristics on line. Weren't extensive so i settled for these http://www.littelfuse.com/data/en/Data_ ... aSheet.pdf
If you take a look at page 5 you will see the time/current characteristics of this particular 300A fuse.
Follow the 300A line up and you will note that this is quite capable of holding a 450A load for about 1000seconds.
A 1000A load would take 20seconds to blow this fuse
Now I don't know what fuses you are using but I would suggest that the fuses are similar in terms of their actions. To corrctley size a fuse you need to know what the fault current is for a dead short accross the battery therminals and the time you need to clear the fault in.
