Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: esc issue
  1. #11
    never mind about smidsy
    For a more detailed answer to your question, if you open up the casing of the electronize you will see a large relay in the middle of the board at one end. This has 8 pins underneath soldered to the board. You have to unsolder these 8 connections carefully then put another relay in it's place and solder it on (look for videos on youtube etc for advice on soldering)
  2. #12
    Can you recommend a good relay? maybe even one with a higher amp rating as a mod for both esc's?
  3. #13
    Linking to this website is a bit odd, so go to hints & tips and then Electronize speed controller external relay mod. Assuming you're using 30a models, it should help.
    http://ukrobotics.com/ukrobotics/index2.htm
    I believe the 15a versions are different.
  4. #14
    I'm using the 15a ones so not sure how they could differ
