Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 68
Thread: Bulldog Breed
  1. #51
    [/quote]
    Get it in the configuration so it works and doesnt failsafe.... then re-set the failsafe positions....not hard.[/quote]
    rebind then (reset dave said )
  2. #52
    Tided the wiring up yesterday, shortened a lot of it so its not all hanging there
    2 jobs left are replace the powerlight as I blew that so bulldogs light will now be red and sort out turning as left is right and right is left, but got 2 months too sort it
    Off too the glade arena in Kidderminster tomorrow but not for robots, day at a reptile expo
  3. #53
    can i reccommend that you move the power light from your gas/link panel as at Guilford i remember that causing a few problems
  4. #54
    For steering it should be a case of flipping the channel (not sure what TX you're using).
  5. #55
    I shall be re-locating the light probably too the back panel since it did cause some issue
  6. #56
    Got the drive working well but as with everything, a new problem comes about
    When trying too fire my flipper, the 'Up' valve gets hot quite quick yet the repay inside doesnt respond and click, tried replacing the main valve head (black cuboid thing) and it still does it
    any ideas?
  7. #57
    Your valve is staying on... When you fire it your turning it off.... Get a multimeter.... And test it.
    Youve probably reversed the channel on your rc by mistake...
  8. #58
    I may well have done as I was flicking them about yesterday but must have hit the valve channel by mistake
  9. #59
    Now with a whole new control system for the flipper, bulldog is coming back barking
  10. #60
    New ram just arrived, new batteries and a suprise, see you at whitwick
