Hmm, I'll guess 7 then. There are other combinations that I think could possibly be right that I could try but then I'd likely just end up cycling through numbers 1-10, which is probably verging on unsportsman-like behaviour![]()
To prevent such unsportsman-like behavior ill keep quiet now until tomorrow evening then announce who is correct or closest and give them a go at naming or drawing on the picture to show where and what robots they can see.
I got 6 points for the robots I found...
The big moment, in order of worst guess to best:
Last Place: Max - 10
2rd Place: Matt and Jamie Tied - 5 and 7 respectively
Winner: Dave - 6
Got it exactly right, well done.
First part of the challenge done, now would you care to point out where and which bots you can each see? If you have actually got it right by seeing them all I will be very impressed... I know where they are and I still struggle to see one or two of them in that picture. Also, so if you're right and i'm ever murdered I definitely want you at the crime scene looking for clues Dave![]()
Hows this ?
I will do my own spot the bot when I am back down the workshop![]()
Dave was very very close, but no Eric Jr in there. Sneakily, I used someone else's robot and have planted Maxus Jr (Anxious) is in there somewhere. Still better than I think I would have done had I not known where everything was.
Here is a closer view of where it's hiding, if no one gets it I have another that makes it pretty obvious:
Where did Scar come from! That was never in the first photo!
It was, I just turned it around so you could only see the insides and a wheel arch. Didnt want it to be too easy :wink:
Well Played.
