Quote Originally Posted by Max
If you have one Gimson directly attached to a 75mm wheel and the other directly attached to a 100mm wheel then thos two wheels would move at different rates making you go diagonally regardless of The gearing between wheels on the same side. You could fix this with travel adjusts if you have a fancy tx.
As to the ratio you want the same ratios the ratio between the wheels, 75:100 or 3:4 or 0.75:1. And then the other way round on the other side. (big pulley always on the little wheel)
cheers! can picture it now. ill scrap that idea then lol
