Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 73
Thread: motors
  1. #31
    gears: http://www.technobotsonline.com/gears/m ... gears.html
    Mod 1 will be fine. though i really don't recommend you attempt your own gearning on your first featherweight.
  2. #32
  3. #33
  4. #34
    Depends how accurate and in what material on what location.
  5. #35
    Max's Avatar
    Member
    If it is on your gears/ pulleys then technobots will drill out the centres for you as long as the bore size isn't larger than the size you want to start off with
  6. #36
    You really haven't listened to the good advice on this thread as far as I can tell (although there is a fair bit of crap in there too).
    For a first bot, DO NOT TRY AND MAKE A GEARBOX YOURSELF. You will will have a hard enough time trying to get the other systems working and put together into a chassis. Buy a couple of drills or the gimpsons and use those as a nice drop in solution. Run them at their rated voltage and use an appropriate speed controller. I'm always a fan of the electronize as they are nice and simple, very rugged.
    Once you have built your first machine and attended an event and spoken to people, you will have a far better idea about voltages, gearboxes etc etc. Trying to machine a mod 1 gearbox without a mill is a pain in the arse at the best of times. Not impossible, just a pain.
  7. #37
    I only can agree with Gary.
    I made assembled quite a few gearboxes myself. Batterydrill based, speed 600-700 and 900 based, and for heavyweights Iskra and Bosch based ones.
    On the other hand, I have acces to a reasonably complete metal working workshop at home, and the support of very fine engineers with even a more impressive array of tools.
    Even then, I opted for Gimsons in the newest Hannibalito to speed up construction and ease of replacement
    The 4th of the line. 1 and 2 (Wedgie) are sold.
    And is in continous use sinds it's first outing, proving very reliable and with a fair turnaround time. (from arena removal to -barring battle damage CO2 filled and recharged in 15 minutes)
  8. #38
  9. #39
    the gimsons motors com in either 9.6v or 14.4v last time i looked and which sabertooth as the 12a ones are ok if you don't intend to do lot of pushing cos i had my robot pushing against me and it kept cutting out for a split second ...... so the 25a ones would be better i think
  10. #40
