Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 73
Thread: motors
  1. #21
  2. #22
  3. #23
  4. #24
    Like so: http://www.argos.co.uk/static/Product/p ... +DRILL.htm
    You can overvolt them to 18V, or use larger wheels to get more speed. Finding the balance between voltage and wheel size will be key to the performance of a thwackbot, as the larger the wheel, the less torque (turning force) the motor has.
    I wouldn't say there is too much difference between the GR01s and cordless drills when it comes to power for a thwackbot. If you really want a fast and meaty drive, Speed 900s (or their cheap eBay replicas) are the sort of motors you want to be considering. The issue with them is that you have to sort out and pay for parts for a gearing system (sprockets & chain, timing belts & pulleys, gears etc)
  5. #25
  6. #26
    Well those drills will be your best bet. Alternatively, these Speed 900 clones are £12 each:
    http://www.ebay.co.uk/itm/300511267976? ... 725wt_1037
    Which leaves you with £16 for gearing. Not entirely impossible I don't think.
  7. #27
  8. #28
  9. #29
  10. #30
    Pulleys and belts: http://www.technobotsonline.com/index.p ... ory_id=197
    Click on 'aluminium timing pulleys' for pulleys, 'timing belts' for belts, and then just match the types up (T5x10mm, T10x16mm etc)
    Drumroll uses T5x25mm for its weapon. T5x10mm would probably be fine for a drive system.
    Sprockets and chain: http://www.technobotsonline.com/index.p ... ory_id=193
    Either the 6mm or 8mm sprockets/chains should be beefy enough for a featherweight. As an example, DB5 (4-wheel drive pusher) uses the 6mm stuff.
