as above im looking for a 100mm stroke and eithe 12 or 24 volt
and gimsons are too expensive for me![]()
could try a ford mondeo seat motor
If a Gimson is too expensive I won't propose a full custom one with an astroflight as powerplant.
Make one yourself if budget is an issue. Some threaded rod, a nut, a drill motor and a bit of grease with something to support the threaded rod. Job done
thanks, but im short for spaceim looking for a set-up like aftershock?
http://www.ebay.co.uk/itm/FORD-MONDEO-M ... 500wt_1287
cheapest supply of actuators..... not the most powerful but can lift a featherweight
thanks for that ill bear it in mind![]()
bump![]()
bump
Jonny had one in the for sale section
